TwinTurbo.NET: Nissan 300ZX forum - stock motor vs. built motor...
NVMYZTT
on January 30, 2001 at 4:01 PM
441 on TD05's? Didn't Fred do 500+ at 17psi pump gas?
posted by Bernie
on January 30, 2001 at 10:10 AM
Plus Im sure there's tons of boltons that Fred has that Mike doesnt... driveshaft, lightened flywheel, etc. It adds up. The ported heads, cams, and cam gears makes a hell of a difference.
DYNO stuff, new thoughts and analysis. Need your thoughts.
BadZCar (FL)
23:40:17 01/29/01
Some thoughts....
B-Ster
00:01:03 01/30/01
I talked to QQQQQman, I assumed he was running stock
BadZCar (FL)
00:10:06 01/30/01
Ron has the same turbos as you (n/m)
wesman [92TT-less ]
00:12:10 01/30/01
Like Mike said, 4th gear and AFC will put you over 500 rwhp. (n/m)
ZBlacktt
00:16:49 01/30/01
I told you before, all my runs were in 4th except for one
BadZCar (FL)
00:19:10 01/30/01
What was your set-up when you put down 375 RWHP (n/m)
SteAmyZ(ztoyz.net©)
00:18:39 01/30/01
Mostly just the basics...
B-Ster
00:34:48 01/30/01
475 RWHP on Stick Turbos....has to be NOS!!!
SteAmyZ(ztoyz.net©)
00:07:49 01/30/01
Never heard of anthing close to that on stock T's (n/m)
wesman [92TT-less ]
00:10:43 01/30/01
Me neiter...I could pull it
SteAmyZ(ztoyz.net©)
00:15:49 01/30/01
Car "Feels" strong as hell... The dyno I went to is
BadZCar (FL)
00:13:09 01/30/01
Bald Tires..
B-Ster
00:36:59 01/30/01
Highest I've seen was Mike H in AZ,put down 400 @ 19psi. (n/m)
ZBlacktt
00:14:51 01/30/01
I put down 358/396 at 15psi. (n/m)
BadZCar (FL)
00:16:24 01/30/01
your profile says denso iridium plugs. wrong plugs. hp loss>
twinz
07:49:17 01/30/01
Did you do the runs with A/F ratio? I dyno'd>>>
Mike (Austin)
09:58:21 01/30/01
Bernie
10:10:29 01/30/01
Yeah. Sounds a lot like Albert's car with low compression.
ZHOUND
12:03:28 01/30/01
stock motor vs. built motor... -
NVMYZTT
16:01:29 01/30/01
No trouble getting tach signal. I backed the boost off to
BadZCar (FL)
12:27:09 01/30/01
